标题: 空气过滤用电纺PVDF-PAN/熔喷PP无纺布复合材料的制备及过滤... [打印本页]
作者: guolvfenlitech1    时间: 2019-5-1 04:46
[attach]2100[/attach]
2019-05-01    环球过滤分离技术网    guolvfenlitech1
摘  要:为开发高效低阻的空气过滤材料,采用静电纺丝技术制备了聚偏氟乙烯(PVDF)-聚丙烯腈(PAN)复合纳米纤维,并与丙纶熔喷非织造布复合制得高效复合过滤材料,研究了PVDF与PAN的质量比对溶液性质、表面形貌、比表面积、透气性和过滤性能的影响。结果表明,当PVDF与PAN质量比为3:5时,其溶液可纺性最好,所得纤维直径均匀,约0.59 μm;利用BET比表面积分析仪测试可得其比表面积约为PVDF/PAN质量比为2:1时的两倍;利用滤料测试仪对PVDF-PAN/熔喷PP无纺布复合滤材的过滤性能进行测试,结果表明静电纺PVDF-PAN纳米纤维层可显著提高丙纶熔喷非织造布的过滤性能,PVDF-PAN/熔喷PP无纺布过滤效率可达99.95%,明显高于熔喷无纺布的过滤效率(65%),过滤阻力为77 mmH2O (1mmH2O=9.8Pa),过滤品质因子达0.0987,远高于熔喷无纺布的过滤品质因子0.0168,过滤效果得到显著提升。
关键词:静电纺丝;聚偏氟乙烯;聚丙烯腈;熔喷无纺布;过滤性能
Abstract: The high filtration efficiency and low flow resistance of air filtration materials were successfully prepared by composing electrospinning poly(vinylidene fluoride) (PVDF)-polyacrylonitrile (PAN) nanofibers with Polyethelyene(PP) melt-blown nonwoven. The influence of the PVDF-to-PAN mass ratio on solution properties, morphology, specific surface area and filtration properties were investigated. The results show that when the PVDF-to-PAN mass ratio is 3:5, the solution has excellent spinnability and the well-distributed nanofibers with mean diameter of 0.59μm can be formed. BET test result shows that it went for nearly double the specific surface area when PVDF-to-PAN mass ratio decreases from 2:1 to 3:5. Besides, the filtration efficient and resistance determined by TSI 8130 filter were tested. Results reveal that electrospinning PVDF-PAN nanofibers can significantly improve the filtration performance of polypropylene meltblown nonwovens, the filtration efficiency of PVDF-PAN/melt-blown PP nonwoven reaches to 99.95%, significantly higher than that of melt-blown nonwoven with 65%, filtration resistance is 77 mmH2O (1mmH2O=9.8Pa), filter quality factor reaches 0.0987, which is more higher than 0.0168 of melt-blow nonwoven. The filtration properties significantly enhances by composing electrosping PVDF-PAN nanofiber with melt-blow nonwoven.
Keywords: electrospinning; poly(vinylidene fluoride); polyacrylonitrile; melt-blow nonwoven; filtration property
作者:王利娜等,河南工程学院 材料与化学工程学院,郑州
通讯作者:辛长征,河南工程学院 材料与化学工程学院,郑州
全文详见中国知网学术期刊优先数字出版。
来源于:中国复合材料学会     www.guolvfenlitech.com
