PTFE覆膜滤料是指将PTFE微孔薄膜用一种特殊的工艺和不同的过滤材料基布覆合制成,具有以下特性:
1.表面过滤,除尘效率显著
2.极佳的化学稳定性、抗腐蚀、不老化;
3.表面光滑、剥离强度高、易清灰,
4.透气性能好,
5.耐高温,有优良的抗结露功能,憎水;
6.过滤效率高,可达99.99%(接近零排放)
7.运行阻力低,过滤风速大,
8.适应范围广,运行费用低,
PTFE microvoid film laminating with various filter material base fabric through one special technology, has the following properties:
1. surface filtration, high efficiency for dust collection;
2. excellent chemical stability, corrosion resistant, not aging;
3. smooth surface, high peel strength, easy to clean ash;
4. air permeability good;
5. high temperature resistance, excellent prevention of frosting, water-repellent;
6. high filter efficiency, could be 99.99% ( close to zero emission) ;
7. low running resistance, high velocity of filtering ;
8. wide applicable range, low operating expenses.
PTFE film laminating filter material could be widely applied to flue gas cleaning, dust control and material recycle etc. fields.
使用温度(℃)operating temperature | ≤130 | 260~300 | ≤204 |
耐酸性acid resistance | 优 excellent | 优excellent | 优excellent |
耐碱性 alkali resistance | 良 good | 良good | 优excellent |
耐磨性 abrasive resistance | 优excellent | 中moderate | 优excellent |
水解稳定性hydrolytic stability | 良good | 优excellent | 良good |
