The density of PTFE is between 2.14 g/cm3 and 2.30g/cm3,melting point is 327℃,decomposed temperature is 415℃.Because of the special chemical construction, PTFE has excellent chemical resistance. All of strong acid, alkali, organize and salt have no effect to PTFE, even at high temperature. But F element and melting alkali metal can corrode PTFE.
PTFE fiber have weak mechanical property because of molecule chain structure, relative strength of fiber is 1~1.4g/d, which is typical soft polymer. So when producing filter felt, normally put scrim between two layers web for improving the strength.
PTFE filter felt has so many outstanding properties, such as high filtration efficiency, easily dust release, acid and alkali resistance and so on. The continuous working temperature is 240℃.At the same operation condition, the service life of PTFE filter felt is one to three times than others.
PTFE过滤材料已在燃煤锅炉,电厂,水泥,垃圾焚烧等行业得到越来越多的应用。
PTFE filter felts are used widely in following industries, such as coal burning boiler, power plant, cement, incinerator and so on.
