The map of scattering intensity versus angle is the primary source of information used to calculate the particle size. The scattering of particles is accurately predicted by the Mie scattering model. This model is rigorously applied within the Mastersizer 2000 software, allowing accurate sizing across the widest possible dynamic range.
During the laser diffraction measurement, particles are passed through a focused laser beam. These particles scatter light at an angle that is inversely proportional to their size. The angular intensity of the scattered light is then measured by a series of photosensitive detectors. The number and positioning of these detectors in the Mastersizer 2000 has been optimized to achieve maximum resolution across a broad range of sizes.
