标题: PTFE Membrane Filter Cartridge with HALAR (ECTFE) Hardware [打印本页]
作者: fluorotech1    时间: 2020-6-19 05:13
2020-06-19  环球过滤分离技术网     fluorotech1
FluoroClear All-Fluorocarbon cartridges are designed for highly aggressive wet-etch and cleaning applications. FluoroClear cartridges are constructed with 100% fluorocarbon materials, providing broad chemical compatibility and temperature resistance. Cartridges are available as flushed & dried or as wet-packed (high Purity DI Water/Hydrogen Peroxide solution). Membranes are manufactured in a cleanroom environment to ensure product cleanliness.
Sanitization/Sterilization:
FluoroClear cartridges may be sanitized using compatible chemical agents.
FluoroClear cartridges may not be autoclaved or steam-sterilized.
Maximum Recommended Operating Conditions
Temperature...................................... 215˚F (102˚C)
FDA Listed Materials
Manufactured from materials which are listed
for food contact applications in Title 21 of the
U.S. Code of Federal Regulations
Toxicity
All components meet the specifications for
biological safety per USP Class VI – 121˚C for
plastics.
Materials of Construction:
Micron Ratings and Dimensions:
Applications
[attach]3914[/attach]
[attach]3913[/attach]
[attach]3912[/attach]
