2020-10-24 环球过滤分离技术网 guolvfenlitech1
General Description:
Lenticular filter cartridges are new type of filter cartridges with depth filter sheets. They are based on a fully new design incorporating the double separator concept.
Applications:
● Particle Removal
● Polishing Filtration
● Final Filtration (germ removal)
● Chill Haze Removal
● Bottling Filtration
● Clarifying Filtration
● Filtration after Stabilization
● Pre-filtration prior to Final Membrane Filters
● Removal of Colloids
Features:
●Backwashable, resulting in high total throughput
●Easy and reliable handling
Rigid external clips prevent damage of the filter sheet during module loading and unloading.
●No filter sheet deformities after heat treatment
●No adverse effects to filter sheets when in contact with hot sanitization or process filtration.
●Increased filtration security
Separator design increases the total stability of the filter cartridges as the
separators fully support the sheet material.
Specifications:
Dimensions
● Outside Diameter: 284mm
● Inside Diameter: 51mm
● Length: 273mm
Material Of Constructions:
●Depth filter sheet: Cellulose fibers, Natural diatomaceous earths,
Perlite, Resins, and etc
●Core/Separator: Polypropylene(PP)
●Double O-ring or flat gasket: Silicone, EPR, Viton
Performance:
● Range of Removal Ratings: 0.1—90µm
