标题: 微球产品参考文献指引 [打印本页]
作者: guolvfenlitech1    时间: 2020-11-7 11:09
标题: 微球产品参考文献指引
[attach]4259[/attach]
2020-11-07   环球过滤分离技术网  guolvfenlitech1
PLEASE SEND US A REPRINT OR A COPY OF YOUR RECENT PAPER DESCRIBING THE USE OF OUR PRODUCT, AND WE WILL SEND YOU A FREE PARTICLE PRODUCT OF YOUR CHOICE (SMALL UNIT) TO SHOW OUR APPRECIATION (LIMITED TO ONE FREE PRODUCT PER PUBLISHED PAPER).
Selected References
Ahmed, S., El-Asser, M., et al. (1980) “Cleaning Latexes for Surface Characterization by Serum Replacement.” J. of Colloid and Interfacial Science 73: 388.
Hechemy, K., and Michaelson, E. (1984) “Latex Particle Assay in Laboratory Medicine, Part 1.” Lab Management June/July(27).
Seaman, G., and Goodwin J. (1986) “Physiochemical Factors in Latex Rapid Agglutination Tests.” Amer. Clin. Prod. Rev. June(26).
Schwenzer, K. MacCrindle, C. (1985) “Particle Concentration Fluorescence Immunoassay: Clinical Applications.” Clin. Lab Prod. Sept(21).
Jolley, M. E., C.-H. J. Wang, et al. (1984). “Particle concentration fluorescence immunoassay (PCFIA): a new, rapid immunoassay technique with high sensitivity.” Journal of Immunological Methods 67(1): 21-35.
Leahy, D., Shah, D., et al. (1992) “A Method for Attachment of Peptides to Solid Surface with Enhanced Immunoreactivity.” BioTechniques 13(5): 738.
Leahy, D., Shah, D., et al. (1992) “Improved Serological Detection of Hepatitis C Virus with a Paramagnetic Microparticles Assay using Multiple Antigenic Sequences.” Transfusion 32(6): 548.
Todd, J., Kink, J., Shah, D., et al. “A Novel Semi-automated Paramagnetic Microparticle Based Enzyme Immunoassay for Hepatitis C Virus: Its Application to Serological Testing.” J. of Immunoassay, Vol. 13 (3), 393
Phillips, D., Reimer, C., et al. (1980) “Quantitative Characterization of Specificity and Potency of Conjugated Antibody with Solid-Phase, Antigen Bead Standards.” J. of Immunol. Methods 34: 315.
Kreuter, J., Berg, U., et al. (1986). “Influence of the particle size on the adjuvant effect of particulate polymeric adjuvants.” Vaccine 4(2): 125-129.
Hadfield, S. G., Lane, A., et al. (1987). “A novel coloured latex test for the detection and identification of more than one antigen.” Journal of Immunological Methods 97(2): 153-158.
Staros, J., Wright, R., et al. (1986) “Enhancement by N-Hydroxysulfo-Succinimide of Water-Soluble Carbodiimide Mediated Coupling Reagents.” Analytical Chem. 156: 220.
Van den Hul, H. and Vanderhoff, J. (1972) “The Characterization of Latex Particle Surface by Ion Exchange and Conductiometric Titration.” Journal Electroanalytical Chemistry 37: 161.
Sinclair, Bob. (1998) “To Bead or Not To Bead - Application of Magnetic Bead Technology.” The Scientist June(22):16-19.
SafarIk, I. and M. SafarIková (1999). “Use of magnetic techniques for the isolation of cells.” Journal of Chromatography B: Biomedical Sciences and Applications 722(1-2): 33-53.
Selected References: Flow Cytometry Calibration, Multiplex, and Absolute Counting Particles
Duling, T., and Waldschmit, T. (1993) “Quality Assurance on Research Instruments Utilizing a 4 Intensity Bead Mixture to Record Sensitivity.” ISAC XVI Abstract #391B, Cytometry Supplement 6: 47: Using RCP-20-5 and RFP-20-5.
Bell, A., and Shenton, B. (1994) “Quality Control in Flow Cytometry.” ISA XVII Abstracts #142B, Cytometry Supplement 7: 38: Using RCP-30-5.
Mathai, J., Bigos, M., et al. (1994) “Analysis of Calibration Data from Flow Cytometers.” ISAC XVII, Abstract # 143C, Cytometry Supplement 7: 38: Using RFP-30-5A.
Bell, A., Barnett, D., et al. (1996) “Quality Control and the Value of Quantitation in Immunophenotyping-A Multicenter Study.” ISAC XVIII Abstract #IH83, Cytometry Supplement 8: 86: Using RCP-30-5.
Iyer, S., Hultin, L., et al. (1998). “Quantitation of CD38 Expression Using QuantiBRITE Beads.” Cytometry 33: 206-212: Using RCP-30-5A.
Lanweiler, M. “Procedure Manual, Flow Cytometry Laboratory, Dartmouth-Mary Hitchcock Hospital.” Web Site: http://130.189.200.66/ProcMan/: Using RCP-30-5 and FP-3056-5.
微球产品参考文献指引Microparticles Literature References
2014/10/25 admin  154
Selected References
Chase, E., and Hoffman, R. A. (1998) “Resolution
