GMP体系术语汇总
nanotech8
2021-3-30 04:17
GMP体系术语汇总
[attach]4686[/attach]
2021-03-30 环球过滤分离技术网 nanotech8
1. receipt:(入厂)接受,验收,进货
2. handling:搬运
3. packaging:包装
4. storage:保存
5. protection:保护
6. comparison:比较
7. identification:标识
8. replacement of identification mark:标识标志更换
9. maintenance of identification:标识的保持
10. records of identification control:标识控制记录
11. tender:标书
12. normative document:标准文件
13. supplemental:补充
14. nonconforming product:不合格品
15. control of nonconforming product:不合格品控制
16. control procedure of nonconforming products:不合格品控制程序
17. tendency of nonconformance:不合格倾向
18. purchasing:采购
19. verification of purchased product:采购的产品验证
20. purchasing process:采购过程
21. purchasing control procedure:采购控制程序
22. purchasing information:采购信息
23. reference standard:参照标准
24. reference instructions:参照细则
25. stockhouse:仓库
26. measurement, analysis and improvement:测量,分析和改进
27. measurement result:测量结果
28. control procedure of monitoring and measuring devices:测量设备控制程序
29. planning:策划
30. preservation of product:产品保护
31. control procedure for maintenance, replacement and records of product identification:产品标识的保持, 更换及记录控制程序
32. procedure for product identification and traceability:产品标识和可追溯性程序
33. conformity of product:产品的符合性
34. monitoring and measurement of product:产品的监督和测量
35. product plan:产品方案
36. control procedure for product preservation:产品防护控制程序
37. method of product release:产品放行方法
38. conformity of product,product conformity:产品符合性
39. product realization:产品实现
40. planning of product realization:产品实现策划
41. product characteristics:产品特性
42. input to product requirements:产品要求的输入
43. product status:产品状态
44. final acceptance of product:产品最后验收
45. procedure:程序
46. program documents:程序文件
47. continual improvement:持续改进
48. procedure for continual improvement of quality management system:持续改进质量体系程序
49. adequacy:充分性
50. storage location:存放地点
51. agency personnel:代理人员
52. submission of tenders:递交标书
53. adjustment:调整,调节
54. statutory and regulatory requirements:法律法规要求
55. rework, vt:返工
56. repair, vt:返修
57. subcontractor:分承包方
58. annex:附录
59. improvement:改进
60. mprovement actions:改进措施
61. on-the-job training:岗位技能培训
62. responsibility of individual department and post:各部门, 各岗位职责
63. change identification:更改标记
64. change order number:更改单编号
65. process sheets:工艺单
66. process specification:工艺规程
67. procedure(process card): 工艺规程(工艺卡)
68. process characteristics:工艺特性
69. Job Description Format:工种描述单
70. work environment:工作环境
71. impartiality:公正性
72. functional requirements:功能要求
73. supplier:供方
74. supplier evaluation procedure:供方评价程序
75. supplier provided special processes:供方提供的特殊过程
76. verification at supplier's premises:供方现场验证
77. supply chain:供应链
78. criteria for supplier selection, evaluation and re-evaluation:供应商选择、评估和再评估准则
79. communication:沟通
80. customer:顾客
81. customer property:顾客财产
82. control procedure for customer property:顾客财产控制程序
83. customer feedback:顾客反馈
84. Customer Service Contact Form:顾客服务联系表
85. customer cummunications:顾客沟通
86. customer satisfaction:顾客满意
87. statistical analysis of customer satisfaction:顾客满意度统计分析
88. customer complaint:顾客投诉
89. identificaion of customer requirements:顾客要求的识别
90. management review:管理评审
91. records from management review:管理评审记录
92. management review control procedure:管理评审控制程序
93. management representative:管理者代表
94. management responsibility:管理职责
95. specified limits of acceptability:规定的可接受界限
96. specified use:规定的用途
97. process:过程
98. complexity of processes:过程的复杂性
99. monitoring and measurement of processes:过程的监视和测量
100. operation of process:过程的运行
101. status of processes:过程的状态
102. process approach:过程方法
103. process controls:过程控制
104. process control documents:过程控制文件
105. process performance:过程业绩
106. appropriateness:合适性
107. changes to contractor:合同的更改
108. contract review control procedure:合同评审控制程序
109. internet sales:互联网销售
110. environmental conditions:环境条件
111. monogram pragram requirements:会标纲要要求
112. type of activities:活动类型
113. infrastructure:基础建设
114. infrastructure:基础设施
115. fundamentals and vocabulary:基础与词汇
116. control of records:记录控制
117. technical specificaion:技术规范
118. process trace sheet:加工跟踪单
119. monitoring and measurement:监视和测量
120. monitoring and measuring device:监视和测量装置
121. control of monitoring and measuring devices:监视和测量装置控制
122. check method:检查方法
123. frequency of checks:检查频次
124. calibration status:检定状态
125. inspection and test control procedure:检验和试验控制程序
126. identification procedure for inspection and test status:检验和试验状态标识程序
127. inspection witness point:检验见证点
128. inspection hold point:检验停止点
129. buildings:建筑物
130. delivery:交付
131. post-delivery activities:交付后的活动
132. delivery activities:交付活动
133. interface:接口
134. acceptance of contract or orders:接受合同或定单
135. type of medium:介质类型
136. experience:经验
137. correction action:纠正措施
138. Corrective action response time:纠正措施答复时间,纠正措施响应时间
139. management procedure for corrective actions:纠正措施管理程序
140. corrective action response times:纠正措施响应时间
141. development activity:开发活动
142. traceability mark:可追溯性标志
143. objectivity:客观性
144. Customer Service Log:客户服务记录簿
145. control feature:控制特性,控制细节
146. control features:控制细则
147. periodic assessment of stock:库存定期评估
148. justification:理由
149. routine:例程,惯例,常规
150. internal communication:内部沟通
151. internal audit:内部审核
152. internal audit procedure:内部审核程序
153. internally controlled standard:内控标准
154. internal audit:内审
155. results of internal and external audits:内外部审核结果
156. competence:能力
157. training:培训
158. training needs:培训需要
159. evaluate:评价
160. records of the results of the review:评审结果的记录
161. review output:评审输出
162. review input:评审输入
163. Purchase Requisition:请购单
164. authority:权限
165. validation:确认
166. concession:让步
167. human resources:人力资源
168. job training of personnel:人员岗位培训
169. qualification of personnel:人员资格
170. equipment control procedure:设备控制程序
171. device type:设备类型
172. order of design changes:设计更改通知单
173. design and development control procedure:设计和开发控制程序
174. design and development:设计开发
175. design and development planning:设计开发策划
176. control of design and development changes:设计开发更改控制
177. design and development review:设计开发评审
178. design and development validation:设计开发确认
179. design and development outputs:设计开发输出
180. design and development inputs:设计开发输入
181. design and development verification:设计开发验证
182. design validation:设计确认
183. design documentation:设计文件编制
184. design acceptance criteria:设计验收准则
185. design verification:设计验证
186. audit program:审核大纲
187. conduct of audits:审核行为
188. audit criteria:审核准则
189. production process control:生产过程控制
190. production process control procedure:生产过程控制程序
191. production and service provision:生产和服务提供
192. control of production and service provision:生产和服务提供的控制
193. validation of processes for production and service provision:生产和服务提供过程的确认
194. production order:生产令
195. identification and traceability:识别和可追溯性
196. identification and traceability maintenance and replacement:识别和可追溯性维护与替换
197. invalidate:使失效
198. market survey:市场调研
199. suitability:适宜性
200. scope:适用范围
201. controlled condition:受控状态
202. terms and definitions:术语与定义
203. analysis of data:数据分析
204. sequence:顺序
205. transfer of ownership:所有权转移
206. system document:体系文件
207. statistical technique:统计方法
208. outsource(vt) a process:外包过程
209. external source:外部来源
210. documents of external origin:外来文件
211. outsource, vt:外协
212. unique identification:唯一的标识
213. maintenance:维护
214. Document Change Control:文件更改控制
215. Request For Document Change(RDC):文件更改需求单
216. control of documents:文件控制
217. documentation requirements:文件要求
218. enquiry:问询,询价
219. field nonconformity analysis:现场不符合分析
220. relevance:相关性
来源于:网络整理,侵权告删
