POREFLON™ is porous membrane made of PTFE.
PTFE stands for PolyTetraFluoroEthylene, it is a kind of fluororesin.
It features chemical resistance, heat resistance, water repellency, high retention of very small particles and high flow capability.
Pore size :0.03~10μm
Thickness:10~100μm
Porosity :25~95%
The characteristic of POREFLON™ is the combination of what is derived from being porous body and being PTFE.
POREFLON™ is used for various purposes.
Chemical liquid filtration in the manufacturing process of Micro Electronics products such as semiconductors and LCD.
For filtration of water solution, we have hydrophilic line-up.
