标题: PALAS GMBH [打印本页]
作者: guolvfenlitech3    时间: 2018-3-9 17:15
标题: PALAS GMBH
[attach]1324[/attach]
2018-03-09 环球过滤分离技术网
公司简介
30多年来,Palas®已经在气溶胶和颗粒技术领域提交50多项专利,建立标准。通过不断创新,我们的产品达到世界一流品质。
我们的宗旨是为客户提供独特的技术和高性价比的产品。Palas®确定了自己在气溶胶发生,气溶胶稀释和气溶胶粒子测试技术领域的全球市场领导地位。全球超过60个国家的著名企业,大学和科研机构信任Palas®的精密技术,选择Palas®产品。
核心竞争力
过滤器/滤材测试系统
气溶胶粒径谱仪
超细粉尘监测系统
纳米颗粒测量技术
颗粒发生系统
稀释系统
洁净室颗粒技术
Company Info.
With over 50 patents submitted, Palas® has set the standard in aerosol and particle technology for more than 30 years. Through continuous innovations, we achieve extraordinary quality in our products.
The result is unique technical and economic advantages for our customers. Palas® has established itself as a global market leader in the fields of aerosol generation, aerosol dilution and aerosol particle measurement technology. Renowned companies, universities and research institutions in approximately 60 countries put their trust in Palas® precision technology.
CORE COMPETENCIES
Filter test systems
Aerosol spectrometer systems
Fine dust monitoring systems
Nanoparticle measurement technology
Particle generation systems
Dilution systems
Clean room particle technology
Filtration &Separation Asia
