查看: 1076|回复: 0
JX Nippon ANCI 投产新型过滤材料
1772
1792
200018718
发表于 2018-12-9 17:17:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
2018-12-09     环球过滤分离技术网   guolvfenlitech6
总部位于美国佐治亚州肯尼索市的JX Nippon ANCI公司日前宣布,该公司已经正式投产JX-CFF(continuous fiber filtration)产品。据该公司介绍,该产品是一种聚酯无纺布材料。相比传统的纺粘无纺布,该产品更加均匀,并可以根据不同孔径需求进行定制。该公司分别在阿拉巴马州的罗阿诺克拥有生产工厂,并在佐治亚州的道尔顿市拥有复合工厂。
JX-CFF是一种100%连续纤维聚酯产品,通过采用热粘合多种聚酯特定组合的专有技术制成,以精确控制孔径和拉伸性能,满足特定客户的要求。 JX-CFF的材料可以包括以下纤维尺寸:
常规纺粘聚酯:5dpf(23微米)
细纤维聚酯:1 dpf(10微米)
超细纤维聚酯:0.07 dpf(2.7微米)
在改变单位重量的同时,使用上述纤维的各种组合以及专有的粘合条件,使JX Nippon能够在各种范围内定制纤维网属性以满足客户的要求。 例如,JX-CFF产品的孔径可以控制在10至100微米的范围内。 此外,网面的特性还能根据JX-CFF中不同尺寸纤维层顺序的不同而有所差异。
而JX-CFF的其他衍生版本,为进一步满足潜在客户的需求提供了多种可能:JX Nippon CLAF(PP或PE增强网)可以有助于清除污垢/灰尘;拥有各自特性的各种薄膜产品; 以及其他无纺布材料,如水刺,熔喷,双组分和纳米产品。
来源:< nonwovens-industry >
英文原文:
JX Nippon ANCI Begins Production of New Filtration Media
JX Nippon ANCI , headquartered in Kennesaw, GA, with manufacturing in Roanoke, AL, and composite manufacturingin Dalton, GA, has begun production of JX-CFF, (continuousfiber filtration), a polyester nonwoven which is much more uniform than conventional roll goods of spunbond and can be customized for pore size requirements, according to the company.
JX-CFF is a 100% continuous fiber polyester product which is made by using a propriety technology of thermally bonding specific combinations of various polyesters to accurately control pore size and tensile properties to specific customer specifications. Materials for JX-CFF may include the following nominal fiber sizes:
Conventional Spunbond Polyester: 5 dpf (23 microns)
Milife Microfiber Polyester: 1 dpf (10 microns)
Milife Ultra-Microfiber: 0.07 dpf (2.7 microns)
Using various combinations of the above fibers along with proprietary bonding conditions, while varying unit weights, allows JX Nippon to customize web properties over awide range to meet customer requirements. For example, the pore size of JX-CFF products can range from 10 to 100 microns. Additionally, web properties can further be influenced by the sequence of layering the various fiber sizes in JX-CFF.
Alternate versions of JX-CFF may include the following pending customer requirements: JX Nippon’s CLAF (PP or PE enhanced netting) which can aid in dirt/dust release; multiple films for unique properties; and other nonwovens such as spunlace, meltblown, bicomponent, and nano products.
转载于:亚洲过滤与分离工业展览
GMT+8, 2024-12-27 19:33 , Processed in 0.166777 second(s), 15 queries , File On.
