查看: 1082|回复: 0
PTFE覆膜过滤材料产品介绍PTFE film laminating filter material
1842
1862
200019074
发表于 2017-8-21 19:30:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
PTFE覆膜滤料是指将PTFE微孔薄膜用一种特殊的工艺和不同的过滤材料基布覆合制成,具有以下特性:
1.表面过滤,除尘效率显著
2.极佳的化学稳定性、抗腐蚀、不老化;
3.表面光滑、剥离强度高、易清灰,
4.透气性能好,
5.耐高温,有优良的抗结露功能,憎水;
6.过滤效率高,可达99.99%(接近零排放)
7.运行阻力低,过滤风速大,
8.适应范围广,运行费用低,
PTFE覆膜滤料可广泛应用于烟气净化除尘、粉尘治理及物料回收等领域。
PTFE microvoid film laminating with various filter material base fabric through one special technology, has the following properties:
1. surface filtration, high efficiency for dust collection;
2. excellent chemical stability, corrosion resistant, not aging;
3. smooth surface, high peel strength, easy to clean ash;
4. air permeability good;
5. high temperature resistance, excellent prevention of frosting, water-repellent;
6. high filter efficiency, could be 99.99% ( close to zero emission) ;
7. low running resistance, high velocity of filtering ;
8. wide applicable range, low operating expenses.
PTFE film laminating filter material could be widely applied to flue gas cleaning, dust control and material recycle etc. fields.
使用温度(℃)operating temperature
≤130
260~300
≤204
耐酸性acid resistance
优 excellent
优excellent
优excellent
耐碱性
alkali resistance
良 good
良good
优excellent
耐磨性
abrasive resistance
优excellent
中moderate
优excellent
水解稳定性hydrolytic stability
良good
优excellent
良good
GMT+8, 2025-3-17 14:43 , Processed in 0.166959 second(s), 15 queries , File On.
