查看: 501|回复: 0
PTFE 除菌过滤膜 PTFE filtration membrane used to kill germ
1864
1884
200019182
发表于 2024-3-27 07:05:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
2024-03-27             环球两个分离技术网          guolvfenlitech6
PTFE 微孔除菌滤膜,由 PTFE 材料经特殊烧结制成.孔径范围 1-0.01μ m, 可与无纺布、
机织布等等基材进行复合制成各种除菌滤料.可用作折叠滤芯、 滤筒等的进滤介质和滤料.可
广泛应用于要求除菌净化的各个领域。
PTFE filtration membrane used to kill germ is made by PTFE material in a sintering way.
The range of aperture is from 1μ m to 0.01μ m. PTFE filtration membrane ,with non-woven and
woven fabric added ,can be used to make kinds of filtration material killing germ. PTFE filtration
membrane can be used as folded filter,filtration material ,etc.In the environment requiring killing
germ and purification , PTFE filtration membrane can be used widely.
产品特点 Product features
1 : 疏水性强, 适用于气体的除菌净化。 2 : 耐强酸碱、 耐高温、 化学稳定性好。 3 :
可复进行高温灭菌, 使用寿命长。 4 : 节能降耗、 降低运行成本, 适用性广。
1: With strong hydrophobic property and application property to gas purification. 2:
Resistance to strong acid and alkali ;Bearing high temperature;Good chemistry stability. 3:Being
disposed to kill germ repeatedly on the condition of high temperature ;Having a long life of use 4:
saving energy and reducing consumption, and reduce the operating cost, wide serviceability.
技术参数 Technical parameters
项目 project
过滤精度(μ m) Filtering precision (μ m)
截留率 Interception rate
最大连续工作压力 Maximum continuous work pressure
最大反压差 The maximum reverse pressure
灭菌温度 Sterilization temperature
气体流量 Gas flow
完整性测试 Integrity test
最小气泡点最大扩散流 Minimum bubble point maximum diffusion flow
技术性能指标 Technical performance index
气体 gas0.2um、 液体 liquid0.2um 气体 gas0.45um、 液体 liquid0.45um
B.P≥0.08MPa,100%异丙醇 Isopropanol ≤5.5ml/min 异丙醇; water=60:40,0.1MPa
△P
应用领域 Areas of application
1 : 制药行业发酵工艺、 储罐、 配料罐等的空气的无菌过滤。 2 : 无菌包装的无菌空气
过滤。 3 : 电子行业中的高纯气体过滤。 4 : 无菌用压缩空气的净化。 5 : 各种特殊溶剂的
除菌净化。
1:Fermentation technology of the pharmaceutical industry; Filtration for gas of tanks without
germ.
2: Filtration for pure gas packed without germ.
3ure gas purification in electronic industry 4: purification of condensed gas without germ.
5: purification of killing germ of all kinds of special solution.
来源于:环球过滤分离技术网            www.guolvfenlitech.com
GMT+8, 2025-4-9 08:55 , Processed in 0.531069 second(s), 15 queries , File On.
