2030-06-18 环球过滤分离技术网 filtratech1 型号:5967B12494 生产厂家:美国Instron公司 主要技术指标: 最大载荷:30kN; 载荷精度:≥±0.5%; 横梁最大行程:1640mm; 整机刚度≥100kN/mm; 有效试验宽度:410 mm; 横梁移动速度范围0.0005~1000mm/min; 横梁位移速率精度: ≥±0.1%; 横梁位置检测精度:0.01mm 有效数据采样频率不低于2,000Hz; 全自动接触式引伸计:标距10-700mm,精度:0.5% 主要用途:用于金属、塑料、陶瓷、玻璃、橡胶、复合材料、电线电缆、薄膜、纸张、纤维等产品的拉伸、压缩、弯曲、剥离、撕裂等性能试验,获得强度、载荷、泊松比、弹性模量等性能指标。 Model: 5967B12494 Manufacturer: Instron LTD, America Main Specifications: Load capacity: 30kN Load precision:≥±0.5% Mixmum crosshead travel: 1640mm; Frame stiffness: ≥100kN/mm; Effective testing wide: 410 mm; Crosshead testing speed range: 0.0005~1000mm/min; Crosshead testing speed precision : ≥±0.1%; Crosshead position precision: 0.01mm; Data sampling frequency:≥2,000Hz; Automatic Contacting Extensometer: Knife edge separation: 10-700mm,precision: 0.5%. Main Application: This testing system is used to test mechanical property for various materials such as metal,plastic,ceramic,glass,composite, electric wire, fiber ,etc. The strength ,load,poisson’s ratio ,modulus of elasticity and stress-strain diagram are avilable. 来源于:网络整理 www.guolvfenlitech.com |
GMT+8, 2026-11-7 01:02 , Processed in 1.006452 second(s), 12 queries , File On.
