滤芯的化学相容性
2022-11-13 17:39| 发布者: guolvfenlitech6| 查看: 448| 评论: 0|原作者: guolvfenlitech6
摘要: 2022-11-13 环球过滤分离技术网 guolvfenlitech6 滤芯的化学相容性 聚偏氟乙烯聚四氟乙烯聚丙稀聚醚砜尼龙硅橡胶氟橡胶醇类 戊醇RRRRRNRR苯甲醇100%RRRRRLRR丁醇RRRRRNRR乙醇RRRRRRLR异丙醇RRRRRRR甲醇R ...
滤芯的化学相容性
聚偏氟乙烯
聚四氟乙烯
聚丙稀
聚醚砜
尼龙
硅橡胶
氟橡胶
醇类
戊醇
R
R
R
R
R
NR
R
苯甲醇100%
R
R
R
R
R
LR
R
丁醇
R
R
R
R
R
NR
R
乙醇
R
R
R
R
R
R
LR
异丙醇
R
R
R
R
R
R
R
甲醇
R
R
R
R
LR
R
NR
碱
氢氧化胺3N
R
R
R
R
R
R
R
氢氧化胺6N
R
R
R
R
R
R
LR
氢氧化钾3N
R
R
R
R
R
LR
R
氢氧化钠3N
R
R
R
R
R
R
R
氢氧化钠6N
R
R
R
R
R
R
R
酮
丙酮
R
R
R
NR
R
NR
NR
环己酮
R
R
R
NR
NR
NR
甲基乙基酮
R
R
R
LR
NR
NR
甲基异丁酮
R
R
R
NR
LR
NR
NR
油
棉籽油
R
R
R
R
R
R
润滑油
R
R
R
NR
R
R
R
花生油
R
R
R
R
R
R
芝麻油
R
R
R
R
R
R
R
其它
苯胺
R
R
LR
NR
LR
NR
R
二甲基甲酰胺
R
R
R
NR
R
R
NR
甲醛37%
R
R
R
R
R
R
NR
汽油
LR
LR
LR
R
LR
NR
R
乙烷(无水)
LR
LR
LR
LR
NR
R
煤油
R
R
R
R
NR
R
苯酚
R
R
R
NR
R
NR
R
吡啶
R
R
LR
NR
LR
NR
NR
松节油
R
R
LR
R
NR
R
水
R
R
R
R
R
R
R
乙腈
R
R
LR
R
LR
NR
硫酸镍溶液
R
R
R
R
R
酯类
醋酸戊酯
R
R
R
LR
NR
NR
醋酸丁酯
R
R
LR
LR
NR
NR
醋酸纤维
R
R
R
R
NR
NR
醋酸乙酯
R
R
LR
LR
LR
R
NR
醋酸甲酯
R
R
R
NR
LR
NR
醋酸异丙酯
R
R
R
R
LR
NR
醚类
乙醚
R
R
LR
R
R
LR
NR
异丙醚
R
R
R
NR
NR
二恶烷
R
R
R
R
NR
NR
四氢呋喃
LR
LR
LR
NR
R
NR
NR
乙二醇类
亚乙基二醇
R
R
R
LR
R
R
R
甘油
R
R
R
LR
R
R
R
丙二醇
R
R
R
LR
R
R
R
芳烃
苯
LR
LR
NR
LR
LR
NR
R
甲苯
LR
LR
NR
NR
NR
NR
R
二甲苯
LR
LR
NR
NR
LR
NR
R
卤烃
四氯化碳
LR
LR
LR
LR
LR
NR
R
三氯甲烷
LR
LR
LR
NR
LR
NR
R
二氯化乙烯
LR
LR
LR
NR
LR
NR
LR
氯利昂TF
R
R
LR
R
R
NR
R
氯利昂TMC
LR
LR
LR
NR
LR
NR
LR
二氯甲烷
LR
LR
LR
NR
LR
NR
LR
全氯乙烯
LR
LR
LR
LR
NR
R
三氯乙烯
NR
NR
LR
LR
LR
NR
R
酸
冰醋酸
R
R
R
NR
NR
LR
NR
盐酸(浓)
R
R
R
R
NR
NR
R
盐酸6N
R
R
R
R
NR
NR
R
硝酸(浓)
R
R
R
NR
NR
R
硝酸6N
R
R
R
NR
LR
R
磷酸(浓)
R
R
R
NR
NR
R
硫酸(浓)
R
R
R
NR
NR
NR
R
氢氟酸6N
R
R
NR
NR
NR
来源于:网络,侵权告删   www.guolvfenlitech.com
GMT+8, 2026-10-20 14:59 , Processed in 0.258601 second(s), 13 queries , File On.
