查看: 945|回复: 1
Instron 5967型电子万能材料试验机
8
8
36
36
发表于 2020-6-18 06:17:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
2030-06-18   环球过滤分离技术网   filtratech1
型号:5967B12494
生产厂家:美国Instron公司
主要技术指标:
最大载荷:30kN;
载荷精度:≥±0.5%;
横梁最大行程:1640mm;
整机刚度≥100kN/mm;
有效试验宽度:410 mm;
横梁移动速度范围0.0005~1000mm/min;
横梁位移速率精度: ≥±0.1%;
横梁位置检测精度:0.01mm
有效数据采样频率不低于2,000Hz;
全自动接触式引伸计:标距10-700mm,精度:0.5%
主要用途:用于金属、塑料、陶瓷、玻璃、橡胶、复合材料、电线电缆、薄膜、纸张、纤维等产品的拉伸、压缩、弯曲、剥离、撕裂等性能试验,获得强度、载荷、泊松比、弹性模量等性能指标。
 Model: 5967B12494
 Manufacturer: Instron LTD, America
 Main Specifications:
  Load capacity: 30kN
  Load precision:≥±0.5%
  Mixmum crosshead travel: 1640mm;
  Frame stiffness: ≥100kN/mm;
  Effective testing wide: 410 mm;
  Crosshead testing speed range: 0.0005~1000mm/min;
  Crosshead testing speed precision : ≥±0.1%;
  Crosshead position precision: 0.01mm;
Data sampling frequency:≥2,000Hz;
  Automatic Contacting Extensometer: Knife edge separation: 10-700mm,precision: 0.5%.
Main Application: This testing system is used to test mechanical property for various materials such as metal,plastic,ceramic,glass,composite, electric wire, fiber ,etc. The strength ,load,poisson’s ratio ,modulus of elasticity and stress-strain diagram are avilable.
人心齐,泰山移。
GMT+8, 2025-3-12 00:47 , Processed in 0.522451 second(s), 15 queries , File On.
