查看: 622|回复: 0
仪器分析测试帮你解读材料性能分析与结构测试
201
201
1683
1683
发表于 2022-5-1 18:18:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
2022-05-01      环球管理分离技术网      guolvfenlitech2
材料化学成分结构测试分析
X射线光电子能谱仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image001.jpg
X射线多晶(粉末)衍射仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image002.jpg
X射线单晶衍射仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg
电感耦合等离子体发射光谱仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image006.jpg
电感耦合等离子体发射光谱仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image007.jpg
原子荧光光度计
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image008.jpg
原子吸收分光光度计
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image009.jpg
紫外/可见/近红外分光光度计
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image010.jpg
紫外-可见分光光度计
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image012.jpg
紫外可见分光光度计
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image013.jpg
傅里叶变换红外成像光谱仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image014.jpg
傅里叶变换红外成像光谱仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image016.jpg
多功能土壤分析仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image017.jpg
X射线荧光光谱分析
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image019.jpg
激光显微共聚焦拉曼光谱仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image021.jpg
500MHz超导核磁共振波谱仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image022.jpg
600M超导核磁共振波谱仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image023.jpg
Bruker 400MHz固体核磁
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image024.jpg
有机元素分析仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image026.jpg
碳硫分析仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image028.jpg
氮氧分析仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image030.jpg
光电直读光谱仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image032.jpg
辉光放电质谱仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image034.jpg
便携式重金属分析仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image035.jpg
离子色谱仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image036.jpg
液相色谱仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image038.jpg
气相色谱-质谱联用仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image040.jpg
凝胶色谱仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image042.jpg
原子荧光光度计
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image043.jpg
材料物理性能测试仪器
激光导热分析仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image044.jpg
热流法导热分析仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image045.jpg
热膨胀分析谱仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image046.jpg
同步热分析仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image047.jpg
差式扫描量热分析仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image048.jpg
差式扫描量热分析仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image049.jpg
激光粒度仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image050.jpg
BET比表面和孔径分析仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image051.jpg
压汞仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image052.jpg
全自动真密度分析仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image053.jpg
Zeta电位测试仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image054.jpg
全自动化学吸附仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image055.jpg
全自动化学吸附仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image056.jpg
粘度计
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image057.jpg
高级旋转流变仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image058.jpg
卡尔费休水分测定仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image059.jpg
红外线水分测试仪/红外线水分计
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image060.jpg
粉体综合性能测试仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image061.jpg
燃烧性能测试
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image062.jpg
氧指数测试
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image063.jpg
锥形量热仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image064.jpg
材料力学测试分析仪器
电子万能材料试验机
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image065.jpg
热机械控制测试系统
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image066.jpg
疲劳试验机
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image068.jpg
高温蠕变持久试验机
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image070.jpg
摆锤冲击试验机
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image071.jpg
落球冲击试验机
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image072.jpg
里氏硬度计
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image073.jpg
洛氏硬度计
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image074.jpg
显微维氏硬度仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image075.jpg
布氏硬度计
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image076.jpg
高温硬度仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image077.jpg
纳米压痕仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image078.jpg
微划痕测试仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image079.jpg
动态力学测试仪DMA
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image080.jpg
湿式摩擦材料试验机
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image082.jpg
干式摩擦材料试验机
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image084.jpg
薄膜残余应力
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image085.jpg
残余应力X射线衍射仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image087.jpg
便携式X射线探伤仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image088.jpg
固定式X射线探伤仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image089.jpg
低频超声检测仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image090.jpg
微振动摩擦磨损试验机
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image091.jpg
摩擦试验机
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image092.jpg
材料光电性能测试分析仪器
动态接触角测量仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image093.png
光学接触角测定仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image094.jpg
全自动张力仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image095.jpg
振动样品磁强计 VSM
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image096.jpg
振动样品磁强计 VSM
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image097.jpg
矢量网络分析仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image098.jpg
/小电流测试系统
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image099.jpg
热激电流测试 TSC
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image100.jpg
热电效应测试 TEES
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image101.jpg
霍尔效应测试系统HALL
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image102.jpg
霍尔效应测试仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image103.jpg
飞行时间测试系统 TOF
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image104.png
半导体参数测试仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image105.jpg
Keithley 静电计
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image106.png
光致发光 PL
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image107.jpg
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image108.png
荧光分光光度计
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image109.jpg
四探针测试仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image110.jpg
材料可靠性性能测试分析仪器
高温老化试验箱
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image111.jpg
温度冲击试验箱
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image112.jpg
高低温交变湿热试验箱
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image113.jpg
高压加速老化试验箱
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image114.jpg
快速高低温交变试验箱
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image115.jpg
电动振动试验台
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image116.jpg
垂直冲击试验台
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image117.jpg
盐雾试验箱
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image118.jpg
高低温交变试验箱
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image119.jpg
高温热处理炉
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image120.jpg
材料特种性能测试分析仪器
热重-红外-气质联用仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image121.jpg
氧弹量热仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image122.jpg
高速拉伸试验机
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image123.jpg
超高分辨飞行时间质谱仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image124.jpg
叱咤红外光谱仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image125.jpg
单柱式电子万能试验机
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image126.jpg
高分辨衍射仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image127.jpg
多功能粉末衍射仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image128.jpg
AFM
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image129.jpg
稳定同位素质谱仪
file:///C:/Users/DouDou/AppData/Local/Temp/msohtmlclip1/01/clip_image130.jpg
来源:二知了,如有侵权,请联系删除  www.guolvfenlitech.com
量天地,求精准;度万物,衡公平。
GMT+8, 2025-1-22 15:41 , Processed in 0.176741 second(s), 15 queries , File On.
